stuck open t-stat discussion
larky
I pulled off the cover to my t-stat and found it stuck open. my question is how will this affect:
-decarb effectivness (used seafoam before i found open t-stat)
-wot rpms
-carb mixure setting
I replaced it but was just wondering about any differences to expect
in case it matters 71' 50hp
thanks
Vlad D Impeller
Re: stuck open t-stat discussion
The next thing to do after decarbing is to change them plugs, cause they're probably all gunked up.
I have found that when a motor is not operating at its optimum temp, they inevitability retain a high level of carbon build up.
studlymandingo
In order for the decarb to be effective, the engine needs to be at operating temperature; I am guessing it never got to that with an open t-stat. You may want to do another decarb; certainly can't hurt...​
