chopperdog
Thread starter- Joined
- Jun 7, 2009
- 71
I actually had a complete valve job about a year ago, maybe less.
Engine started running rough 2 days ago, just while I was warming it up at the house, getting ready to take the boat out.
When I started it, it ran, but rough. In fact I just started it a few minutes ago, with the valve cover off. It started right up, and ran, but rough.
So, I took the valve cover off. The fourth valve from the front of the boat is stuck down, compressing the spring down further than the other valves appear to move.
The rocker arm was off of the valve, just turned sideways.
The push rod seems to be in good shape.
Okay, so now what. Does this sound like a bent valve? Is it possible that the valve is just stuck?
Do you think it damaged the piston?
Can I try to loosed up the valve without removing the head?
Thanks for the input.
