kippstakes
Thread starter- Joined
- Jun 10, 2013
- 117
going nuts here. rebuilt my carbs about two weeks ago... that is all new gaskets, all fresh fuel line, and a fine de-filthing. finally put them back on and the engine (which ran well with the carbs absolutely gunked to custard) won't run for more than a few seconds. i checked the float bowls and noticed that one wasn't filling. took carb off, polished the needle and jet (again), made sure it wasn't sticking anymore, put the carb back on. double checked both bowls for fuel, good to go. also checked fuel pump and its adjoining lines- all working fine with great flow. just doesn't want to start. it will run for an instant with the choke on, then, with the choke off, will run for just a bit longer when cranked. a few times i was able to get it running for about a minute by manipulating the choke on/off- but grudgingly and barely alive. it seems to be getting fuel for an instant and then quits. again, all fuel lines are rock solid as is the bulb.
running out of ideas fast.
help please!
thank you
help please!
thank you
