1995 Sea Pro Alpha 1 gen II 3.0LX
Turn key to on and gauges go on turn to start and it does nothing. Jump starter with screwdriver and it turns over and starts and runs fine. Ok so I checked fuse and than pulled dash and on back of key switch it has a yellow wire with red stripe that gets power when key turned to start. Now looking at starter the solenoid has same yellow and red wire. Testing it on starter it has no power when key is turned. So somewhere in between the wire is broken? Any idea where a common issue might be. Not exactly an easy wire to test, mostly behind fiberglass. Is it a single wire or is there a junction in there somewhere?
Going out this weekend if I have to start it with a screwdriver!
