lindy46
- Joined
- Nov 27, 2008
- 3,886
Re: Stumped with 18hp Evinrude
That hollow piece (barrel) will come out - normal. The needle threads into the barrel. Put the barrel back in the opening. Then put 2 or 3 packing washers in the opening. Put the needle back in but don't try to turn it. Add the packing nut and snug it down. That should prevent the barrel from spinning in the hole. Now tighten the needle. If the packing nut is tight enough, the needle should turn with considerable resistance, and it should thread down into the barrel.
