Barramundi NQ
- Joined
- Jul 3, 2014
- 342
Sounds like power loss more so than weight from massive water ingress. Your tyres would be flat with an extra 3-4000 lbs. You most probably have some wter, weigh bridge will reveal that for you. If power is down, weight a little heavier, it might just tip the balance to not getting boat ip out of the water under full throttle.
Maybe check the throttle cable while your at it that WOT is actually wide open at the 2 barrel carb.
