stupid question - trailer lights
redneck joe
but its me and its electrical...
no trailer lights. working just fine last time i checked them on the truck but that is gone now using the car which i used to bring home from MN. only used a couple three times since and the wire stays tucked up in a storage area in the trunk.
to determine if car side just tester pointy thing to the green plug, turn on some lights and stick the other pointy thing into the other holes and look for voltage?
Does your truck have separate trailer light fuses (mine does)
redneck joe
truck is gone, this is car and afternarket added so assuming no. everything worked when i used the truck.
Jeff J
The exposed pin on the car side should be the ground. Check for voltage at other pins against it. If that works then the trailer ground is the first place to look when nothing works.
I have also had the fixtures lose ground individually along with badly corroded bulb sockets. Maybe the most common failure I see is the cheap clip on wire splices the trailer manufacturers like. Uncommon for these items to all go bad at the same time.
Occasionally I run into a situation where someone has removed the ground wire from the trailer expecting the ball to provide the ground. It will make intermittent contact at best.
Ifishmuskie2
I always run the ground directly to each light. I just did a trailer. All wires are covered to prevent mice attacks. I use led and don’t unplug when launching.
Use a meter to check vehicle side.
Jeff J
I always unplug the lights when dunking the trailer. When I was a kid a wet trailer shorted out my Dad’s truck. Later in life I had 2 incidents where a wet trailer shorted. One of those was a wire shorted to the frame and the other was a bad fixture. I pay more attention these days so most problems get found at home rather than at the boat ramp but I still unplug just in case. Newer vehicles may be better protected but burnt wire smells while stranded on the ramp are hard to forget.
Fixtures may have improved some over the years but wire hasn’t.
airshot
I hear ya, been dragging trailers for over 60 years and can recount many times poor connections got me in trouble. Some time back, I said enough
Is enough. Bought spools of wire so each run would be one solid wire with no connections except the fixture it was connected to. Then used sealed joints by soldering then shrink wrap with silicone grease inside. More time and expense but never another problem. When buying new to me trailers, the first job was a complete rewire. Today with LED lights, no excuse for faulty cinnections....except for vehicle. I always get factory tow packages
even on used vehicles and so far no wiring issues on vehicles. Over the years I gave saw some real doozy wiring jobs...some so bad you can only laugh at them. Do it once and do it right, then enjoy trouble free trailer ing !
Pmt133
And sealant lined heat shrink . I use led lights that are supposed to be waterproof ....so far so good .😁
I haven't touched trailer wiring on the boat in 15 years. Only trailer I wired, one thats used the most and coincidentally the only one that works every single time.
Jeff J
I had to do some wiring maintenance on my current boat trailer a year after I bought it. Haven’t had to mess with it since (11 years). The trailer it replaced needed half of the “waterproof” fixtures replaced during its first year, just before it was stolen at the boat ramp.
Jeff J
Sealed heat shrink, sealed solder sleeves, crimp connectors with attached sealed heat shrink, and all the other fancy products available are all good products that not everyone has quick access to. The key is to seal the connection. Just putting silicone on cheap crimp splices (I refuse to use these on anything) and over grounds will delay any problems for many years.
redneck joe
got my tester in, but too many irons in the too many fires but i'll let you know
Captain of the Double G's
The only stupid question is the one not asked
