Submerged Batteries....HELP!
lazypt
My auot bilge pump wasn't working properly and we had tremedous amounts of rain the last 2 days. I went and checked on the boat tonight and the water level had reached the self bailing cockpit. I believe that it was motly if not all freshwater in the boat but I managed to turn the pump on and bail out the boat but nothing else works, no lights, no trim & tilt, and no crank. There were bubble coming from both negative posts and the after the eater drained there is a gray film that rubs off the positive and all the connections are corroded.
Do I need to buy two new batteries again? I just bought them last year, Interstate batteries.
Dunaruna
Re: Submerged Batteries....HELP!
What type of batteries are they? You need to clean and test them to determine if they are toast or not.
lazypt
Bought 2 new batteries, a new switch and all new breakers and toggle switches.
Everything works as it should!!!!
199675hpforce
Dood i used to work at a Golf Course we sprayed off the batteries almost every day. Helped out with terminal corrosion you should be fine unless some nasty water got inside the battery which shouldnt have.
lazypt
one wouldn't hold a charge and I have been stranded at sea before and it is no fun!
