patjay6666
- Joined
- Jul 11, 2004
- 16
I have a Yamaha 115 and my boat and motor were under water for about 1/2 hour.Alarge wave cameover the back and the back of the boat and the motor went under water . I was able to get the boat out of the water and home . I pulled the plugs and cranked the motor over for several minutes to try and get rid of most of the water(freshwater) . I drained the carbs . I pored 2 cycle oil in the plug holes and cranked the motor over several times then waited a few minutes then did it again , about 6 or 8 times . I squrited 2 cycle oil into the carbs and started the motor , it smoked like crazy but ran . I pulled the plugs and squirted 2 cycle oil into the plug holes again and then squirted 2 cycle oil into the carbs and started it again and ran it for several minutes . I waited for a while and started it again and ran it for several minutes again . Motor seems to run OK but do I need to do anything else ? P.S. I'm new to boating and bought this boat equiped the way it is but I don't think the back of the boat and the motor should have went under water . I have a 1986 15ft fiberglass boat and it has a Yamaha 115 on it . I wonder if this motor is too big for the boat . I wonder if it should have , like a 80 hp motor or something on it ? Does this 115 weigh too much ? Any thoughts appriciated .
