Substitute for OMC Adhesive M and Needle lubricant
mimo777
I am doing the waterpump on my 120 evinrude, and I need to find these chemicals or suitable replacements? does anyone know what will work? Thanks.
realboats
Re: Substitute for OMC Adhesive M and Needle lubricant
Mimo, 3M #847 Gasket Adhesive is Adhesive M. Your dealer can order this. Some people are using rtv's such as Permatex Ultrablack for this but I don't know how well that works.
DHPMARINE
Generally on a water pump,nothing works better than silicone sealers.<br /><br />DHP
DHPMARINE
Actually meant I use nothing instead of silicone sealers on a water pump.<br /><br />DHP
rodbolt
ohhhh I was gonna get ya DHP :) :) 3M weather strip adhesive will work and is obtainable on the weekends. vasoline will work for needle bearing assy lube. what part of the water pump calls for needle bearing assy lube?
DHPMARINE
Not a bad idea to lube the impeller housing insert.But I confess ... I use OMC Triple Guard there.So actually,you did get me Rodbolt.<br /><br />DHP
