Re: Sucking air V4 1979 johnson 115
when i first go to take off it will sputter & not come off plane. makes a fluctuating high pitch low pitch noise. i do not have a tach so i can not give u numbers. it will do this for a minute or so sometimes longer. sometimes i back off and try to shift back into gear. anyway it will all of a sudden go like hell and take off. seems to be fuel starved and then finally gets gas. then i can go full blast and then have period of intermittent power loss. i hooked up a portable tank with new gas and oil and still got the same results. that is how i eliminated bad fuel. If it is an air leak it must be within the area within the engine area. this has been going on for over a yr i had thermostats replaced thinking it was running cold, replaced a power pack, had carborators rebuilt. I will have a compression tester to test the cylnders this week. i kept think it was fuel but this has happend over many tanks of gas and i have a water seperator. they sems to seem melting of somthing underfly wheel. Would a stator just go bad or could it intermittenly fail.
