Suggest a prop
yellj
Did all the research I could, pulled the existing prop seems to be out of balance, shaft didn't wobble. WOT is 4900RPM, measured diameter 14 or 14.25, 3 blade, no idea on pitch, this number was on the inside, could not make the number out on the outside. 48-8328 34 61 23. Don't care about losing a mph or two top end, just looking for something to pull the kids wake boarding. Not ready to invest in SS, suggestions would be appreciated.
junior1113
Re: Suggest a prop
thats 23 pitch which id put back on or go to 22 4 blade wot rpms should be 4400-4800
yellj
Re: Suggest a prop
Can't seem to find a 22"pitch 4 blade, if I stayed with 23" 4 blade, would I be ok with RPMs, again losing an MPH or 2 is not a concern
junior1113
Re: Suggest a prop
yea tough to find a 4x 22 in alluminum 4x 23 allum. sould be fine drop about 150 rpms which is ok. you may not lose any top end change will be little
yellj
Re: Suggest a prop
Thanks Junior, will post how it turns out when I get it on, hope it cures the vibes
