Suggestions for a good shop tachometer
Sylva-Ranger
I whant a good, reliable induction self powered tachometer.
​- for use when testing/adjusting outboard motors or other small engines and small 2 oor 4 strokes vehicles.
​- for bring whit me for testings outboards on the lake.
​-For RPM up to 12 000 or more.
-Sefl powered , no wires on 12 volts.
-Need to be adjustable for diff?rents ignition/cycles/strokes
​I have this one, that have all the features i whant.......... Exept it's unreliable and always run erraticcaly :
http://www.esitest.com/328.html
Maybe i'm just not Lucky but see many review whit the same complains.
​Any sugestions ?
Sea Rider
Hardline Hour/Tachs are excellent products, doesn't need a ground wire as other brands. Compact. All induction tachs are bit erratical while reading idle RPM, will read correct when more throttle is given. Excellent for prop maximizations.
Happy Boating
Sylva-Ranger
Finaly i found a Electrospeciality model 329 , it's look like the Tiny-Tach but the baterys is easily replacable and it's adjustable for 6 diff?rents type of ignition/cycles combination.
​Thank you for suggestions !
http://www.esitest.com/329.html
Sea Rider
Know the Company well. Have great electronic testers to troubleshoot outboards too. A real + for hour/tach being battery replaceble, no ground wire required and multi firing sequence programming.. Excellent purchase.
The only down side I see is that pick up cable is attached to right side of meter, good for reading while tillering port side, for starboard side reading, cable will need to make a U turn instead running straight on tiller as in other brands models in which pick up cable is left hand attached.
Happy Boating
