Hello to all of you people of knowledge and boating itch-pain.When summerising the mid -nineties 3.0 liter OMC Cobra performed perfectly on muffs.Then in the lake (salt water)when put on load it started heating up and when the temperature reached 180 I switched it off and paddled to the slip.Took the boat off the water on the trailer and started in on muffs again -the temperature started to descend,but still some steam came out along from the outdrive with some hot water.Unfortunately at that moment the starter defected so I couldn`t continue with my observations.My first guess is that the impeller has gone south and since I don`t have any info from the previous owner or maintenance records,I want to ask you if you can link me to an on-line info about how should the outdrive impeller be changed .Thank you!
