Sunray Escapade
escapade
I have a project that is underway and i'm glad i found some where to ask some questions
Here is my project so far
http://s35.photobucket.com/albums/d195/viper_coleca/Boat/
I need to finish removing some rotten wood, before i can work on installing a floor.
What is the best tool for removing some of the overlapping fibreglass that was used to hold down the old flooring (still some rotten wood underneith) I'm also trying to find some pictures of the boat or one of same model when it was new, the only info I have of the boat is on the metal hull ID plate
Boat Manufacture: Sunray Boats
No. 8411908
Model: Escapade D-L
If anyone wants to share some ideas or tips I would really apperciate it
escapade
Re: Sunray Escapade
issue is I need to cut some fiberglass out of the boat, so sounds like sanding discs for an angle grider would be the best option thanks
escapade
Re: Sunray Escapade
looks like i have found some more info on the boat, i was searching for photos online and found this one
so my boat is a 1975 Sunray 15.6ft Runabout
the boat photo'd above is close to me as i'm going to try and get some photos just to get some ideas of what i'm going to do when i restore her
escapade
Re: Sunray Escapade
i went to look at flooring today 3/8" marine plywood should do the trick, and then marine carpeting? or is there something else that i should be doing to keep the floor in better shape?
escapade
Re: Sunray Escapade
what would be best to cover the marine plywood? carpet? or something else???
bscleo
Re: Sunray Escapade
use carpet only if it's your last resort - it always holds moisture - your worst enemy - i'm putting a new floor in my 88 sea ray right now and am going to either Rhino-Line it or use Uniflex 255 Aliphatic from rotdoctor.com - These coverings will also act as a first line of defense from water and still give you tread opposed to poly paint that doesnt. hope that helps and Good Luck!
tallcanadian
Re: Sunray Escapade
length 14'6
beam 72"
depth 32"
weight 605 lbs
max h.p. 55 hp
weight capacity 1065 lbs.
you got a great boat there. good luck.
escapade
Re: Sunray Escapade
where did you find that info? not sure if thats totally correct thought the plate near the splash well says max 65HP?
Gary H NC
Re: Sunray Escapade
What are you using to redo the stringers? Have you checked the transom for rot? All of that needs to be done before the floor goes in.
by the looks of the pictures you have some severe rot and probably some wet foam to remove.
It may be a lot of work but thats a cool old boat and should be easy to work on.
tallcanadian
Re: Sunray Escapade
also, do you have the hull i.d number? top right hand corner on the transom.
escapade
Re: Sunray Escapade
on the metal plate mounted near the splash well
Sunray NO. 8411908
escapade model: escapade D-L
not quite sure but the plate does say 65 HP
couldn't find the the hull ID
the transom is in great condition and the stringers have some rot got it all dug out and replaced with newer wood and glassed in the ends to seal it completely
escapade
Re: Sunray Escapade
here is a picture of the plate
escapade
Re: Sunray Escapade
got the transom all sealed up, still waiting for the floor to arrive at the hardware store, one step closer to being in the water boating season 08!!
tallcanadian
Re: Sunray Escapade
the hull id number should be on the top right hand corner on the back of the transom, if you were facing it. that would tell you the year. but none the less you got a great boat there. have you physically measured the centreline length? i'm only asking for my own info. i've got brochures here.
escapade
Re: Sunray Escapade
inside the under the splash well? or outside where the motor mounts?
