Al Mottola
- Joined
- May 1, 2005
- 36
I just picked up an old Super Snark sailboat in need of repair. The previous owner used it, but I believe that he did not know too much about the boat. Hence I have some questions.<br />1)Should the rudder handle pivot in the aluminum bracket. The handle appears to have slotted holes which allows it to swing from side to side before it moves the rudder.<br />2)Is it possible that a foam boat with ABS outer cover can become water logged? This boat is much heavier than the published 50lbs. <br />3)What type of rope should I use for the rigging of the sail?<br />4) What is the best way to repair cracks and small holes in the ABS outer cover?<br /><br />Thanks in advance, <br />Al
