Super Snark Sailboat questions
Al Mottola
I just picked up an old Super Snark sailboat in need of repair. The previous owner used it, but I believe that he did not know too much about the boat. Hence I have some questions.<br />1)Should the rudder handle pivot in the aluminum bracket. The handle appears to have slotted holes which allows it to swing from side to side before it moves the rudder.<br />2)Is it possible that a foam boat with ABS outer cover can become water logged? This boat is much heavier than the published 50lbs. <br />3)What type of rope should I use for the rigging of the sail?<br />4) What is the best way to repair cracks and small holes in the ABS outer cover?<br /><br />Thanks in advance, <br />Al
ED21
Master Chief Petty Officer
Re: Super Snark Sailboat questions
1. Do you mean tiller? The tiller is meant to lift up to make moving around easier.<br />Or does the the tiller have an extension?<br />The tiller shouldn't have much side to side play w/ the rudder. When the tiller moves, the rudder moves<br />2. I'm sure it could get waterlogged if the shell has cracks in it & it sat a lot in the rain. <br />3. Braided dacron usually. A boat that size probably doesn't much matter as long as you can handle it & it runs through blocks. It's been a long time & I don't remember how they are rigged.<br />4. I've never know anything to stick well to ABS
Al Mottola
1. I was referring to the tiller handle. I don't think any side to side play w/o the rudder moving is any good.<br />2.I have had it sitting on it's stern and water keeps dribbling out. <br />3.Thanks. <br />4. I agree, I am hesitant to use expoy as it might just pop off.
