Supertech Marine grease for trailer?
Condor1970
Anybody use the blue Supertech Marine grease for their trailer bearings?
Any issues with it?
dingbat
Typical lithium complex grease. No problems with wheel bearings unless you have disc brakes, then I would want something with a higher drop point
robert graham
I've used that green Supertech Marine grease just about everywhere on the boat, trailer, etc. for years with no problems....
nimmor
I started using it about 2 years becasue it was readily available. No problems yet. I took my hubs apart at the beginning of the year and noticed no play in the bearings. The grease I have been buying is blue though not green or brown. I wonder if it is differant colors depending on what part sof the country you live in.
tpenfield
I bought 2 large tubes of it at Walmart this year for pre-season boat prep. . . It was right next to the miracle formula that seals blown head gaskets and cracked engine blocks :D , , , , , , I used it on just about everything that needed grease and then some. . . . . My only comment is that is a bit 'thin' verses the more name brand stuff that I have used in the past.
