supplies for project?
Andy in NY
Okay, as spring approaches I am gearing up to repair a crack in my hull as well as rip out the floor, stringers and foam.
I need you guys to help me with what I will need for supplies (glass, resin, foam, etc). It's for my 14' MFG tri hull.
Any and all help is appriciated.
jcsercsa
Re: supplies for project?
HAy Andy , in my thread on page 2 it might be 3 I have a list , my is a 15.6 foot tri-hull and i also did my transom !! you might also if you are going this far its not much more work and then you will have a hole new boat !!! John
Andy in NY
I looked through, but didn't see any list. I saw a post where you asked Oops! if he saw your list, but I didn't find the actual list!
Can you post it here for me?
When you did your transom, did you take the cap off?
jcsercsa
Ok I have updated my parts list .
1] epoxy- 635316 5gals $230.00
2] matt fg-10550 15 yards $ 48.00
3] 8.5oz 2x2 twill fiberglass e cloth
fg-7725-38 10yards $ 97.50
4] 10oz E-glass
FG-c1050 10 yards $ 66.00
5] FLAER [canbsal] 4gals $ 22,25
6] Foam-0216 16lbs kit two kits $118.00
Rollers
7] fr 2301 1 inch $ 6.50
8] fr-1213a 3 inch $ 6.70
total $ 594.95
take the matt out if your using epoxy , it was on page one !!!
And USComposities has the best price on this side of the rockies, and some great people that worked there , they called me when i missed up the order, I recommend them to everyone !!! John
Andy in NY
John, I just read all the way through your thread and noticed that you glasses the entire inside of the hull, which I am not planning on doing. I only plan to coat the deck, stringers and transom in resin. How many gallons will I need just to do that? 2?
jcsercsa
Hay Andy , you must have read something wrong , I didn't glass the hole hull ?? when you glass the stringers , you start with the glass going two inch's out on to the hull , then 4 inch's out then the last layer 6 inch's out !! when your doing the transom you have to do the same, on my boat , my transom doesn't cover the hole stern !! but even if yours does its the same over lap frist 2 inch's then 4 then 6 inch's !!!!
I ordered the 6 and a half gal, kit and went threw 5 gals !! US Composites it was 234.00 if i remember right , now if you use polly it will be cheapier !! hope this answers your question , John
Andy in NY
Okay, maybe I looked at your pictures wrong, just seemed like you glasses the entire inside of the hull...
Is there anything wrong with going with poly?
jcsercsa
HAy
Nope not a thing wrong with poly , you have to make sure that you ruff up the hull where you are going to lay it , polly will not bind to the fiberglass, its a mechanical bond , where epoxy has a chemical bond it binds right to the old fiberglass!!
For what you are going to us your boat for poly will be great , I just like epoxy I know it , have worked with it before , and i trust it !! John
jcsercsa
OHH yea Andy when you put the stringers in you have to bed the in something . I used PL premium , the thing is you dont want the stringers to touch the hull , it can make hard spots and then crack the hull , John
Andy in NY
i knew about bedding the stringers. what exactlly should i use?
jcsercsa
Thats up to you , you can use peanut butter , in oops thread he has the mixture for that , i just went the easy way and used the PL , John
