youmansjason
- Joined
- Jun 3, 2005
- 73
I really need some help with my hydraulic surge brakes. I have a 2007 tandem axle trailer with a Fulton A60 (6000 lb rating) surge actuator.
Basically, my brakes quit working. So, I thought I would try bleeding the lines, so used the method of attaching a hose to the bleeder valve and opened up the bleeder valve on the furthest away caliper. Then, when I push in the actuator rod with a screwdriver, it will depress in with very little resistance, but it won't come back out and no brake fluid came out of the bleeder valve. I thought I would need to push it in and out several times to build up pressure in the lines to bleed them out, but I can't get the rod to come back out.
Do I have a problem with my master cylinder or something? My trailer is only 3 years old and always used in freshwater.
