Scott Kirkman
Thread starter- Joined
- Sep 18, 2009
- 21
I'm not sure exactly what motor I have, the case is from a 74, but I think the power head is an '86, based on the carbs. If it matters I'm running a jet lower unit. I've cleaned the carbs completely and had it running great at one time. A few weeks back, I hit the wake of another boat at speed and the motor went to about half speed. I think I stuck a float. I took the carbs apart and re-cleaned and checked the float drop, then re-assembled. Now when I give it throttle, it briefly goes to top RPM's, then drops, then goes back up. It will do this for 10-20 seconds, then run normally. If I slow back down to idle or shut it off, it repeats the process. Any thoughts?
