Survey
Lpgc
I've wondered how much alignment changes between engine off and engine putting full torque to the drive, transom and engine mounts anyway...
mr 88
Should be zero difference. Straight inboards are aligned with engines off . So a 36" boat with twin 502's when taking off is going to develop gobs of torque, the cutlass bearing ( a 6" long plastic sleeve in the prop shaft struts ) takes all torque. If it's off by hundredeth's of a fraction , you will feel it . The engine mounts have extremely hard rubber in them and really just isolate the engine vibration from the stringers ,which keeps the rest of the boat from any vibration . In a I/O the transom should have zero flex as well , regardless of torque transferd through it . Usually if it goes out of alignment its because of poor construction, as in weak stringers , lag bolts used to secure the engine mounts to the stringers or water intrusion in the transom or stringers . Engine mounts in cars are different and you may see the engine rise a bit when torque is applied , but the drive system is designed to flex more or less through the drive shafts universal joints .
Boaterdan278michigan
@Boaterdan278michigan . . . any updates on this? I know things get tougher to move forward during the winter and the holidays. Just wondering if you made the offer and had the survey ?
Thank you for reaching out. We are waiting until after the holidays. My wife specifically asked me to put a pin in the search until after holiday season. The information shared here has been helpful, lots of good minds here. I will update when the search resumes. Thank you.
My wife asked me to postpone the search until after the holidays. We will resume the search shortly after first of the year. I will update this thread as soon as things progress. I've gotten a lot of valuable information. Thank you all.
drewm3i
In my experience, alignment is a "set it and forget it" type of thing. Every time I have checked alignment on one of my boats it has been close enough; I have never had a couple issue either thankfully. The only points of failure IMO are a rotten/sagging structure; I am sure fasteners can also wear out over time--especially the rear engine mounts which rely on shock absorption from rubber discs.
Thank you.
