I recently took apart a lower unit on a 1980 dt65 to replace a bearing and cannot get it back together???? Any help I can get would be greatly appreciated
Are you sure you put the unit back together properly?
Most times it is just a matter of lining up the drive shaft with crank shaft splines along with the water tube and shift shaft.
So where are you having the problem
