suzuki 1980 dt65 lower unit installation
rynerice
I recently took apart a lower unit on a 1980 dt65 to replace a bearing and cannot get it back together???? Any help I can get would be greatly appreciated
rynerice
Getting the lower unit bolted back onto motor Not sure why it won't go back in.
99yam40
Are you sure you put the unit back together properly?
Most times it is just a matter of lining up the drive shaft with crank shaft splines along with the water tube and shift shaft.
So where are you having the problem
