i have a thread at 2cool and TFF, here's the links http://2coolfishing.com/ttmbforum/showthread.php?t=164362, http://texasfishingforum.com/forums/ubbthreads.php/topics/2303598/1, but basically i got a suzuki 40, early 80's model...long story short i bought it and it wasn't running right, was told it needed carb rebuild, took it to a mechanic who said he did that, also checked compression said it was good...now i got the boat back and took it to the lake, started up just fine, ran just fine...FOR ABOUT 3 minutes..made it halfway across the lake, then it just sounded like it ran out of gas, or just lost power or something, just died not immediately but gradual decrease in power until it died...checkd all the obvious things like the bulb it was primed, all that...was sounding like it wouldn't crank over so we loaded it back up and came home...got home and hooked it up to the hose, it cranked over and started for a second then died...then wouldn't crank again so i stopped... any suggestions guys? it will start only after it has been sitting for a while, it runs for 10 seconds or so, then dies and will not crank over until it sits again...to me this is sounding like a carb still? getting too much gas? any help and/or suggestions are welcome........... just recently i took the carb off and made sure it was all clean and the float wasn't stuck...everything looked clean and not stuck...I did notice i got it started and while running for 5-10 seconds i no longer have a pee stream...the pee stream WAS working the other day and even last night when i had it started for a few seconds...today..NOTHING
