Suzuki Control Box
bitsy4643
Can someone identify part number for kill [safety] switch and ignition key for the Control Box photo below. This is an exact duplicate of my control box, but kill switches and ignition switches with keys on Ebay do not correspond with this particular box. Can anyone point to where I might get these. Thanks
bitsy4643
Still waiting on an answer on the above. Kill switch is different from most Suzuki kill switch surely someone on this forum with knowledge of Suzuki outboards can answer this.
Silvertip
You would have better luck posting in the Yamaha/Suzuki part of the forum. Both the kill switch and ignition switch quite possibly can be replaced with generic "off the shelf" equivalents. You need a "push to choke" ignition switch for an outboard and a kill switch for a two stroke both of which are available here on iboats.
eddie haskell
looks like a Suzuki NA12S, it can come with a different switch, a key that inserts, or a key that fits over the switch, either way you turn to start, push to choke, and the terminal side is the same connections (electrical)
