Suzuki DF 50 Power Trim service
Poorman
I am searching for the proper way to change the fluid. I see the plastic fill plug up top but if I let the trim down I can't access to fill. Also I am looking for the right drain screw. I removed the screw on bottom that is a 6mm thread with universal phillips or ten mm wrench to remove. I removed this but it appears to be dry. I know there is oil in it because it still raises up..Any help would be much appreciated.
DF50
s/n 05001F-151919
Thanks Billy
99yam40
Re: Suzuki DF 50 Power Trim service
why do you want to change it?
It is a sealed unit and should not need changing.
If contaminated then the whole unit needs to be disassembled and cleaned, repaired and filled as you put it back together
