suzuki df140 2012 crankshaft bearings
raczekp1
I run into rebuilt motor, suzuki df 140 2012.
on crankshaft bearings is some scoring, crank is perfect only needs to polish.
i dont know which bearings to order.
i need standard bearings but on parts listing is few to choos.
can anyone helpm to point which one to order. here is a photo atached.
lakensea
Short answer is you can't as there is no such thing as "standard bearings". Each throw on the crankshaft is coded, as is each saddle in the crankcase. Your service manual explains the proper procedure for determining the initial bearings, and then how to measure to see if you need to change them. Dealers order a complete bearing assortment kit, use what is needed and return to factory, and then gets billed for the bearings used.
raczekp1
yes you are right. block is coded BBBBB and crankshaft is coded 22222. on edge of old bearings there is no color code= no one color/
