bone-a-fide
Thread starter- Joined
- Oct 15, 2008
- 11
The facts: Overheat alarm gone off 2 of last 4 trips. 2 trips between with no alarm. Definitely seemed HOT to touch, so thinking no false alarm. Last trip, let cool for 30 minutes, started up no alarm, but quickly came back on after a few minutes of running. Limped in on trolling motor. Engine is old suzuki (1987)oil injected 115hp 2 stroke. Tested compression, even at 120 all 4 cyllinders. Believe oil flow to be good, only based on no oil flow alarm, which has happened before due to clog so I believe it works. Engine is "peeing" out pee-hole. Checked water intake both times with nothing visible blocking.
The questions: What are possible causes? Can you still have a good pee-stream and have not enough water flow to properly cool engine (bad impeller)? What further should I do to troubleshoot, before hitting up my mechanic?
Thanks for any help!!!!
