Suzuki dt 25 cooling problems
Dawson_872
I have a 1982 Suzuki dt 25. It will pee for a minute then the steam will become weak. I have replaced the impeller and thermostat.
99yam40
possibly someting is plugging/restricting the flow to the Tell tale.
have you tried to blow compressed air into the TT hole while this happens to see if that changes things up?
Dawson_872
Yes nothing changed. I put the muffs on and it is peeing ok, but there is no water coming out of the exhaust and the cylinder temp is at 200. Is that normal?
