Suzuki dt25 cooling issues
thriller
1995 suzuki dt25 was over heating. Water was sporadic coming out when I first started it up but then quit. Water pump in good shape but found that there was a couple of pieces of gasket material stuck in the input of the water pump. With the bottom off the leg off I can not blow from the bottom pickup tube with either a hose or a compressor to the pee hole. Tried with thermostat out as well with same results. Any hints?
