BoatAddicti0n
- Joined
- May 19, 2010
- 43
Any input will be really appreciated!
Not being really experienced with outboards, but not (so) stupid, I have been trying to make my engine perform well at high RMP, but I have failed.
Happens that my Suzuki DT40 (1990), which is (was) in quite good shape fires 100% successfully, runs perfectly at low RPM, and idles forever.
However, it stalls/fails after some point when I push(open) the throttle, recovering if I release the throttle. It actually runs at high RPM, but fails after some time, lets say 10-15 seconds. Seems like missing fuel or something like that. Note here in Sweden the water is today ranging close to 42 F.
WHAT I HAVE DONE:
I have ensured new/clean gasoline, new fuel hose connector toward engine(was broken from last year), new external filter, cleaned the "internal" filter, new plugs, connected a straight fuel line(no filter or bulb), cleaned the carb, but unfortunately did not change the behavior. There was some resin in the bottom of the carb float chamber, and cleaning the carb seems to have improved the performance (not the bugging behavior). I have been playing with the carburetor's pilot air screw, which of course changes the performance, but did not change the behavior.
WHAT I HAVE NOT NOT NOT DONE:
- Did not change the pump
- Did not change the fuel hose connector toward the tank (that seems OK)
- Did not change the fuel line.
QUESTIONS:
- Should I change the PUMP, clean it, or anything?
- Any other suggestion?
THANKS A LOT!
WHAT I HAVE DONE:
QUESTIONS:
THANKS A LOT!
