Hot or cold, it will turn over great for about ten seconds then when you try it a second time the gear engages starter seems to try but won't turn it over? If you wait about 5/10 minutes it will turn over good again, then the same thing no turn over? It will pull start with a rope. After getting it started with the rope heading back to shore, I tried to trim the motor up did not raise and The TACK maxed out and water temp Gage fell to O, let go of the trim botton they both return to normal. The engine WILL raise if it's not running? The trim down works and affect's nothing? Help!!!
