suzuki dt65 1990
ourhellhouse
can i check wot the spark plug gaps should be and torque setting , NGK B8HS
also a grinding sound when put into forward or reverse? many thanks in advance
ARGYLL
Re: suzuki dt65 1990
Plugs Come With Pre Set Gaps . Put In Hand Tight Then A Quarter Turn With Spanner . Gearbox Crunch Dose Not Sound Good Try Changing Oil At The Bottom Of The Leg .good Luck
ourhellhouse
PHP:
thnks for the info
