Suzuki DT65
andrew j cox
For every 6 Yammys I get the odd one that’s not, now a DT65 Suzi old girl early 80 s, another brand I’ve never toyed with, in for impeller and check over after 4 years stored, any problems with these?
tommarvin
Ensign
Dude you making money fixing outboards?
All outboards are the same carbs or EFI.
Change the impeller,gear lube amsoil tested with 10% water in it,
Clean the carbs/EFI like all the you tube videos, fresh gas with stabil 360 marine.
Clean the plugs never buy new plugs they never fix any problems.Waste of money.
Remove plugs and spray fogging oil in each cylinder, turn the flywheel to make sure shes not seized up.dont turn the key until you know shes not seized up.
New on motor fuel filter.
Tassie 1
G'day mate,
It's the model with the red stripe on the cowl?
otherwise known as the " Disprin" model
( disolves in water ) due to corrosion in salt water,
l got given a dt 50 yrs ago with that problem, couldn't be bothered spending a lot of money on it,
ignition system problems
took it to the tip.
