suzuki dt75 warning buzzer
shade752
i have a 1986 suzuki dt75 it runs fine until you get wot shortly after the warning buzzer comes on. if you slow down the buzzer will go off. if you run at 1/2-3/4 throttle buzzer never comes on. water pump is one year old. not sure if temp. sensor was bad or not. thanks
SpinnerBait_Nut
Re: suzuki dt75 warning buzzer
Yamaha/Suzuki Outboard Troubles and Repairs
ADK_Boater
Hey shade752,
I have the same problem. Did The waterflow switch solve the problem?, or was it something else? I was about to replace the overheat switch to see if that cures things.
