Fabbe2
Thread starter- Joined
- Jun 19, 2011
- 36
Hej everyone! I am new to the forum but already got some useful information from older posts.
My boat is a 5,5 meter Swedish day cruiser from the mid 60s in good shape, it is equipped with a 93 Suzuki DT85. Running very well, even while wakeboarding if the sea far up in the north doesn't freeze.
Unfortunately there is one issue with the engine that I couldn't figure out:
The engine runs well under all conditions when I stay above approximately 3000rpm which is about 20kn/h. In calm weathers without bigger bumps to the boat there is no problem going full speed but if there are more waves and it's getting bumpy the engine will slow down to a rev limit under 3000rpm. No waring light will appear, no warning buzzer sounds.
Trying to idle for one sec as mentioned in the manual doesn't solve the problem. I have to shut down the outboard and start again. After this procedure it revs as normal up to higher rpm with no limiter.
Things I have checked:
-Fires good on all 3 cylinders, spark plugs replaced and in perfect condition.
-Spark plug wires, caps and coils normal reading with ohmmeter.
-Oil flow, oil level, block temperature and water flow sensors checked without failure.
-Carbs clean, fuel hoses and filters with no problem.
-Primary compression checked, good and equal pressure on all 3 cylinders.
So here we are. Seems like an electronic problem.
Does anyone experienced problems like these?
What to check next? Wiring? CDI?
Thanks for helping out!
