mattyrich
Thread starter- Joined
- Dec 27, 2008
- 112
First off, My motor is a 1995 Suzuki DT75 two stroke...So I hooked up a tach that I got free the other day which was set at 6P, on the back of the tach. (6 Pulses???). When I ran the motor it settled at 1100 rpm's and was idling as it normally sounds after warm. When I checked the manual, the table said that my motor should idle at 600-700 rpm's... I wasn't sure If maybe it( the tach) was reading double what it should, meaning that my motor was actually idling at approximately 550 rpm's instead of 1100 (what it was reading)... this seamed like it could be a reasonable explanation from a friend since the motor doesn't really sound like its idling 400 rpm's over what it should( 700). Im thinking that I need to wait to take it on the water and see what it reads at running speed and at WOT... then I'll know if its even close to correct... thanks again,Matt
:confused; Could anyone describe the specifications of tachometers and how they relate to suzuki and/or other outboards... i.e. what does the p stand for on the back of the tach (pulses or poles) or does is change with brand? also, If my motor is idling at 400 rpm's over what it should, what is the first step that I should do to correct this?
Thanks...
Thanks...
