Swap carbs from Force 75hp to Chrysler 105hp
George Pan
I want to check something to my upper carburetor because is leaking again after the service . The point is that i have 3 carbs from a force 75hp . They seems identical except the screw of air mixture (force carb have it outside to the side) . I change the jet screw at inside from my Chrysler .
Is ok to procced ? I am need something else to be safe ?
thanks
Nordin
If they are identical and you change the jets, yes I think it will work
Maybe Frank will chime in. He will know.
Check also that the choke connecting bars will fit.
Frank Acampora
You can swap the carbs BUT you will reduce the engine performance! The 75 HP carbs have a 1 3/16 diameter venturi while the 100 carbs have a 1 5/16 diameter venturi. Additionally the 100 carbs have a larger butterfly and inlet to the manifold. Yeah, it will work, but why try to strangle an engine that was really only delivering about 90 HP?
