First, a little background, I don't have a clue what I am doing.<br /><br />My boat came with a Humminbird Piranha Max 20 fishfinder. I decided I would like to add a finder to the bow so I purchased a Humminbird 525. <br /><br />It turns out to be on the same frequency as the Max 20 and is actually a little larger than I want for the bow anyway.<br /><br />I decided to replace the Max 20 with the 525 but the transducer cable is not pulling out and there is no access to the cable tray.<br /><br />Can I just swap the heads and deal with replacing the transducer if it finally dies?<br /><br />They are both 200KHz and 20 degree. The one that came with the 525 is a little larger (I think) but the specs seem to be the same. Are there other specs I should be looking for?<br /><br />If this will work, I'll look for a small unit on a different frequency later.<br /><br />Thanks
