Swap lower units from 73 to 75 Johnson?
Timguy
I am trying to figure out if I can swap lower units off of a Johnson 70ESL 75E to a 85ESL 73M.......what do you think? Linkages are different at the powerhead.....prop shafts are identical. Thanks, Tim
Timguy
Re: Swap lower units from 73 to 75 Johnson?
Ok thanks, probably a difference @ the splines into the powerhead.....I have not taken the motors apart yet. Poor engineering to uncouple the shift rods, any suggestions to make it easier? Thanks, Tim
Faztbullet
Will not interchange as different driveshaft splines and gear ratio...
Timguy
Ok thanks, any hints to get gearshift linkage disconnected more easily?
