Dawn Tolliver
Thread starter- Joined
- Jul 3, 2021
- 25
Is it possible to change splines to a smaller diameter one. Due to wrong size circumference of the gimbal bearing being wrong. Stern stays off about an inch from seating. There's 2 rubber rings at base of spline. Should there be two or just one at the very base of the spline. Could that keep it from going in? The other spline slids right in up to where it's supposed to go. Mind you it's just the spline. So can I change them out? I don't want to tear it all apart again! So I thought this might be easier! This is on the boat I couldn't even get the alignment right. Got that figured out. Also other spline feels tight in the gimbal and is the same length as the old one on the drive.Mercruiser sent the wrong gimbal! Should be a warning to test gimbal on the spline before seating for fit! Always think of that **** a day late and a dollar short! Thanks Guys and Gals for any help
