Swapping power head
Nicola
Hi big fan of this site I don post much but I read a lot, many useful information...
My question is: is it possible to swap power head of 1977 35 hp evinrude 35703h with a good running power head from 35 hp johnosn j35elcig...
I do have manual for the johnson one to help out...
Any advice will be very appreciated TY
Nicola
Daviet
Re: Swapping power head
Do they both use the same base gasket?
Nicola
Not sure about what you mean by base gasket
Daviet
The gasket between the power head and the exhaust housing, if they are the same there is a chance that they will interchange. Some other things need to ckecked to be sure.
Nicola
The part # is different but from looking at diagram the 2 parts look like they are the same...
Does evinrude use a different way to catalog their parts??
Maybe because is much older numbers just changed??
I dont know if it helps I do have exhaust from the johnson too except the lower unit...
Daviet
By looking at the parts breakdown for both engines it looks like the exhaust housing has a different part number also, don't think they will interchange. You could look in the "Top Secret File" sticky, there is a list of salvage yards there, give one of them a call and see if they have an interchange guide, maybe they can help you out.
Daviet
Let us know what you find out, someone else might be trying to do the same thing.
