swapping power pack crossflow ,looper
Thank you Dhadley for your answer on v6 v8 power packs. I needed to know this because I need a power pack or timing base for my 1991 v6 looper. I am trying to track down used parts that will work. The question I have, is wether a 1991 v6 crossflow powerpack would be the same as a 1991 v6 looper power pack? Are they interchangeable? They have different part numbers. I just received the service manual that describes all of the tests, and will be checking it out this weekend, so I should know for sure. Thanks, JD
