Swim Platform and Lily Pad Float
arminius
I'm looking at buying a 2009 18' Larson runabout with a swim platform on the back. Wondering if that is an ideal setup to have with the lily pad float? I'm new to using the lily pad floats and wondering if there is anything else I should consider when picking out a boat?
wahlejim
How large is the swim platform? Depending on the size of the lilypad, rolled up you are looking at a +- 2-3 ft diameter roll, which tiese really well onto swim platforms that cross the entire transom. If the boat allows for tying the rolled up pad to the transom hooks, you are in great shape for that use as it doesn't take up any space inside as you are cruising to your swimming destination.
arminius
Here is a pic of the platform. does it look large enough? 00b0b_fmZjsPjiROv_600x450.jpg
wahlejim
Absolutely! You should be able to rig something up to tie it to the cleats at the stearn and the tow hook. Great setup for the pad.
90stingray
No Title
I bought these anchors and installed them for our pad. They work perfect for a 2" strap!
