Swim Platform Re-Hab
Woodonglass
Yup, you'll need to use a Dremel or a Drill with a grinding bit and grind the cracks open and then sand the gel coat back away from the cracks a couple of inches down to bare glass. You'll end up with a "V" shaped repair. Depending on how deep the repair is you may need to fill with filler. Then you will use a layer of CSM, then a larger layer of 1708, then 2 larger layers of CSM to complete the repair. Then some fairing material. Then sand and then gel coat or paint to finish.
akcooper9
Thanks. Supplies arrive Wednesday. Plan to grind and prep this weekend. Will get pictures up to inspection.
