ryno1234
- Joined
- Dec 8, 2014
- 167
I have a swim deck that looks worn. I want to refinish it during the offseason.
In looking at the swim deck closely, it appears that it was coated with some sort of shiny, thicker material. I'm not sure if that's epoxy, polyurethane, some or lacquer or what exactly. It's thick enough to where you can see a side profile of its thickness when some of it chips off.
I'm intending to sand the entire thing down and then refinish it.
I have questions, however:
- Should I teak oil it and call it good or should I apply a coating to it like it has now? It seems a coating would likely last a lot longer, but perhaps more difficult to apply. The deck is ~20 years old and still is largely protected by whatever that material is.
- If I apply the coating, would I *also* teak oil the deck before coating it?
- The anti-slip / anti-skid would need to be redone as well. In looking into this, these seems to be so many products, its difficult to understand what would be the correct one of this type of application. It appears that whatever is on there now is a mix of the main coating with grit mixed into it.
