Swim step restoration - What type of wood is this?
KM7
I'm restoring the swim step on my 1992 FourWinns Horizon 200. I removed the wood from the swim step a couple of years ago and the pieces have been in the garage.
Can someone tell me what type of wood this is ?
What would you recommend for restoring it? Sanding + Teak oil?
Something else?
Should I put a little marine sealer into the screw holes in the fiberglass of the swim step before I attach the wood?
Thanks
KM7
That's what I thought. So sand it and use Teak Oil to restore it, right?
chevymaher
Just put the teak oil on with a paint brush and let it soak in. It will look fine. I use boiled linseed oil once in the spring and once before I winterize. I never did any prep at all. Yours looks alot better than mine started out. It was white practically. Only thing I did anything to was the ladder steps. I used the green side of a kitchen sponge and scrubbed the oil in before I wiped the excess off. It had a black nasty something build up. Dead algae is what I think it was. Really it just likes being oiled.
KM7
Here are the pieces after sanding. Can I do something to get the black color out of the wood?
wood bleach or oxalic acid to kill the fungus (black stuff)
