switch box replacement
twebb
I replaced one switch box about 6 months ago, and I hear you should do both at the same time. Is it to late to do the other one now? motor has only run for about 5 hours since I replaced the first one. Or should I have the new one checked first? thank for the help
Re: switch box replacement
Ayuh,.... What motor ya workin' on,..??
twebb
1986 mercury 90hp I6
bilge rat jim
Merc (and CDI) recommend that you change both switch boxes at the same time. They claim that a faulty bias circuit on the old switch box will affect the new switch box, causing failure. I have seen this only a few times, and always, the new switch box failed immediately upon start-up.
Disconnect the battery. Disconnect the White/Black jumper between the switch boxes and check the resistance from each boxes White/Black terminal and engine ground. You should read 14-15,000 ohms on both switch boxes. Any problem on the bias circuit and BOTH switch boxes must be replaced as a set. If both your switch boxes are within range, you will probably be OK.
