UncleWillie
- Joined
- Oct 18, 2011
- 3,995
Re: switch panel hook up?
In summary.
One lead goes to the Electric choke on the engine. (And most likely also the Ignition Coil.)
The other goes to the Panel fuses but the Gauges share the fuse with the bilge pump.
Recommendation,
The gauges should remain fuse protected.
Move the gauge supply over to the ACC FUSE.
Isolated the ACC FUSE Supply from the other three fuses.
Supply the Bilge Pump, NAV and Blower (3) Fuses directly from the Un-switched 12v power.
Supply the ACC Fuse from the Switched, Small RED side, of the Key Switch.
ACC and Gauges will shut off with the key. The other 3 will be hot continuously as desired.
It is a little complicated but easily doable for a little effort and almost no cost.
Alternately, add an under panel, in-line fuse to the Gauge supply and move it to the key switch.
We are closer!
In summary.
Recommendation,
We are closer!
